[GRASS-user] Problem with r.basin in grass7
Helmut Kudrnovsky
hellik at web.de
Tue Nov 18 07:24:14 PST 2014
Andrea Timmermann wrote
> Hi Margherita,
> Thanks for your answer. I am sorry I did not explain well what I
> meant.
> When I delete all files and start again, I get again stuck at that point.
> What I do is: delete all files, set region, run r.basin, get the error ...
> detele all files, set the region, run r.basin, get the error ....
> I just tried it again ..
> Thanks,
> Andrea
> Gesendet: Dienstag, 18. November 2014 um 09:38 Uhr
> Von: "Margherita Di Leo" <
> diregola@
> An: "Andrea Timmermann" <
> timmermann@
> Cc: "Helmut Kudrnovsky" <
> hellik@
> >, "GRASS user list" <
> grass-user at .osgeo
> Betreff: Re: [GRASS-user] Problem with r.basin in grass7
> Hi Andrea,
> On Tue, Nov 18, 2014 at 3:55 AM, Andrea Timmermann <
> timmermann@
> > wrote:
> Hi Helmut,
> Thanks for your email.
> I set again the area and resolution with g.region before running r.basin.
> I also deleted all files except my DEM.
> Now I get a different error ...
> When I run
> "r.basin map=map at Elevation prefix=o
> coordinates=-71.10394196,43.9865230801 threshold=19005
> dir=C:\\Users\\Andrea\\Basins"
> I get:
> Building topology for vector map <o_map_ord_1 at Elevation>...
> Registering primitives...
> 10 primitives registered
> 558 vertices registered
> Building areas...
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 20
> Number of primitives: 10
> Number of points: 0
> Number of lines: 10
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> Updating attributes...
> r.to.vect complete.
> All in RAM calculation...
> ERROR: Region resolution and raster map <o_map_strahler> resolution
> differs. Run 'g.region rast=o_map_strahler' to set proper region
> resolution"
> I run g.region rast=o_map_strahler, but then I have to delete
> all files and start over again running r.basin.
> Yes if you change the region you have to delete the files created in the
> previous run (if they have same name) or allow overwrite.
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at .europa
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
can you test it with the nc sample dataset?
otherwise could you point to the DEM you're using or make the dataset
available?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5173574.html
Sent from the Grass - Users mailing list archive at Nabble.com.
