[GRASS-user] Problem with r.basin in grass7
Helmut Kudrnovsky hellik at web.de
Tue Nov 18 07:54:51 PST 2014
Andrea Timmermann wrote
> Hi Margherita,
> Thanks for your answer. I am sorry I did not explain well what I
> meant.
> When I delete all files and start again, I get again stuck at that point.
> What I do is: delete all files, set region, run r.basin, get the error ...
> detele all files, set the region, run r.basin, get the error ....
> I just tried it again ..
> Thanks,
> Andrea
> Gesendet: Dienstag, 18. November 2014 um 09:38 Uhr
> Von: "Margherita Di Leo" <
> diregola@
> An: "Andrea Timmermann" <
> timmermann@
> Cc: "Helmut Kudrnovsky" <
> hellik@
> >, "GRASS user list" <
> grass-user at .osgeo
> Betreff: Re: [GRASS-user] Problem with r.basin in grass7
> Hi Andrea,
> On Tue, Nov 18, 2014 at 3:55 AM, Andrea Timmermann <
> timmermann@
>  > wrote:
> Hi Helmut,
> Thanks for your email.
> I set again the area and resolution with g.region before running r.basin.
> I also deleted all files except my DEM.
> Now I get a different error ...
> When I run
> "r.basin map=map at Elevation prefix=o
> coordinates=-71.10394196,43.9865230801 threshold=19005
> dir=C:\\Users\\Andrea\\Basins"
> I get:
> Building topology for vector map <o_map_ord_1 at Elevation>...
> Registering primitives...
> 10 primitives registered
> 558 vertices registered
> Building areas...
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 20
> Number of primitives: 10
> Number of points: 0
> Number of lines: 10
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> Updating attributes...
> r.to.vect complete.
> All in RAM calculation...
> ERROR: Region resolution and raster map <o_map_strahler> resolution
> differs. Run 'g.region rast=o_map_strahler' to set proper region
> resolution"
> I run g.region rast=o_map_strahler, but then I have to delete
> all files and start over again running r.basin.
> Yes if you change the region you have to delete the files created in the
> previous run (if they have same name) or allow overwrite.
> Best regards,
> Dr. Margherita DI LEO
> Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at .europa
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
could you post also the exact commands of your steps?
e.g.
g.region -a -p rast=yourdem align=yourdem
r.basin --verbose elevation=yourdem....
g.region
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5173590.html
Sent from the Grass - Users mailing list archive at Nabble.com.
