[GRASS-user] wxGUI raster digitizer available
Roy royroge at outlook.com
Thu Nov 20 00:18:12 PST 2014
Awesome !! Thank you very much Anna !
Il 18/11/2014 05.19, Anna Petrášová ha scritto:
> Hi all,
> I added raster digitizer in r62792 in trunk. You are welcome to test
> it and report bugs/enhancements.
> It currently allows to draw areas, lines and points and specify width
> to buffer individual features. We can discuss some changes in gui
> interface and behavior if you find the current one intuitive.  There
> is still a lot to improve especially in the drawing part (needs some
> refactoring of the old drawing code).
> Features:
> - draw area, line, point
> - specify buffer width for individual features to create for example
> circles, roads of certain width...
> - specify background map
> - simple undo
> - save button to save results during drawing
> - keeps drawing order in the output raster map
> - change color of drawing
> - doesn't block gui when exporting raster (which can take some time)
> Does not support (yet?):
> - adding labels
> - interactive setting color of raster cells (not planned, there are
> other tools)
> - vector export/import
> Known issues:
> - r.in.poly supports only CELL (I just realized that, this must be
> changed)
> - various small drawing issues
> - slow when exporting features with buffers (r.grow is slow, probably
> because it's a script)
> Anna
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141120/69479e28/attachment.html>
