[GRASS-user] Confused when using i.fusion.brovey
Nikos Alexandris
nik at nikosalexandris.net
Mon Nov 24 10:24:27 PST 2014
Michael & Co,
I am trying to iron out the hpf fusion implementation before attempting
to integrate it in i.pansharpen. There is an undesired effect when
running the i.fusion.hpf script which I don't understand.
It's quite obvious that the algorithm is not uniformly applied through
out the entire computational region when just when nearing the edges of
the image(s). It is visible as a thin darker frame (a few pixels wide)
identified all-around, near the edges of the output image. Especially
when forcing high modulation factors (to increase sharpness of the final
product).
I guess that an (r.m)filter expert would probably identify the problem
quickly. If you zoom in to the example pictures illustrated in
<https://github.com/NikosAlexandris/i.fusion.hpf/blob/master/Documentation.pdf>,
or if you simply run it in your own images (just use center=high and
modulation=max), you can see in the effect in the edges of an output
(pan-sharpened) image.
Anyone willing to help?
Thanks, Nikos
Michael Barton wrote:
>> Nikos,
>> Have you considered adding HPFA Image Fusion Technique as a method
>> in
>> the i.pan.sharpen module?
Nikos:
> Of course. First, however, I want to complete a stand-alone version.
> Then, check for integration.
