[GRASS-user] Regarding issues with v.class.mlpy
Pietro
peter.zamb at gmail.com
Thu Nov 27 07:43:06 PST 2014
Il 27/nov/2014 09:35 "Nikos Alexandris"
> Have you also http://scikit-learn.org/stable/ installed?
As Nikos suggested you should install sklearn library and make this library
visible to the python interpreter modifying the python path.
You can check if your setup is corrected trying: "import sklearn" from the
python shell in the GRASS GUI... If not exceptions are raised then you have
setup the python path correctly.
Pietro
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141127/1349f845/attachment.html>
