[GRASS-user] how to change all cats in a vector line
Helmut Kudrnovsky hellik at web.de
Sat Nov 29 15:29:25 PST 2014
Michael Barton wrote
> Hi Markus,
> What I'm trying to do is start with a raster stream map from r.drain and
> convert it to a sequence of vector points, where each point has
> information as to its position along the stream. I then use the points for
> sampling a stream profile and related information. Oddly enough, with all
> of the very useful stream analysis modules, there is nothing I could find
> to generate the data for a stream profile (distance from outlet or from
> headwaters vs. elevation).
> v.to.points does a nice job of creating a sequence of evenly spaced points
> with information about their location along a line (the "along" field).
> BUT, if the line is composed of multiple segments or even if it has an
> irregularity in it, the "along" values start over again from 0. The only
> way I can use it is if I have a very clean and continuous vector line with
> only a single cat.
> This has proven surprisingly difficult to obtain reliably from my raster
> stream map. So far, the only way has been to do a two sequences of v.clean
> (with thresholds 1.5 X the raster resolution) and v.build.polylines. If
> you have any better suggestion, I'd love to hear it.
> Thanks again for the polylines idea. That was a big help.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Nov 29, 2014, at 10:20 AM, Michael Barton <
> Michael.Barton@
> > wrote:
>> Thanks. This helped.
>> Michael
>> C. Michael Barton
>>> On Nov 29, 2014, at 1:23 AM, Markus Neteler <
> neteler@
> > wrote:
>>> On Sat, Nov 29, 2014 at 6:16 AM, Michael Barton <
> Michael.Barton@
> > wrote:
>>>> I have a vector line that is divided into 12 cat values. I’d like all
>>>> of the
>>>> line to have a single cat value. I’ve tried v.category to no avail. If
>>>> I
>>>> delete all categories and then add new categories, I get 12 cats again.
>>>> And
>>>> I can find no other way to get a single cat for the entire line.
>>>> Hopefully
>>>> someone can tell what I’m missing here.
>>> Please try to use
>>> http://grass.osgeo.org/grass70/manuals/v.build.polylines.html
>>> Markus
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
http://grass.osgeo.org/grass71/manuals/r.stream.extract.html ?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/how-to-change-all-cats-in-a-vector-line-tp5175575p5175634.html
Sent from the Grass - Users mailing list archive at Nabble.com.
