[GRASS-user] Grass70 win7 r.basin
    Margherita Di Leo
    diregola at gmail.com
    Thu Oct  2 05:07:56 PDT 2014
[cc'ing list again]
Jose,
I'm not a windows user, this is also a reason why keeping the list cc'ed is
a good idea. The problem you mention is in g.extension, not in r.basin, is
windows related, and most likely has already been solved in more recent
versions.
HTH,
madi
On Thu, Oct 2, 2014 at 1:51 PM, José Anderson <joseandersonbatista at gmail.com
> wrote:
> Margherita,
> excuse me for skipping your turn...
> Have you succeeded r.basin (r.stream.* as well) on win7/8?
> Rgs
> 2014-10-02 7:07 GMT-03:00 José Anderson <joseandersonbatista at gmail.com>:
> > M,
> > I'm typing 'g.extension extension=r.stream.stat' for r.stream.stat and so
> > on.
> > The msg it gives is that ' File is not a
> > zip file'
> > Tks
> > Em 02/10/2014 04:22, "Margherita Di Leo" <diregola at gmail.com> escreveu:
> >> Hi Jose,
> >> On Wed, Oct 1, 2014 at 11:09 PM, José Anderson
> >> <joseandersonbatista at gmail.com> wrote:
> >>> Ok, César, Margherita,
> >>> maybe another issue (remembering I'm on grass7/win7) is installation
> >>> of dependences of r.basin: r.stream.stats r.stream.distance and
> >>> r.stream.order are missing because g.extension returns "File is not a
> >>> zip file" when trying to add them.
> >>> The rest r.stream.basins and r.stream.extract are present.
> >>> Could that be an issue?
> >> That is definitely an issue. You need to have all the dependencies
> >> installed in order to get r.basin working. What is the command line that
> >> gives you that error?
> >> Best regards,
> >> Dr. Margherita DI LEO
> >> Scientific / technical project officer
> >> European Commission - DG JRC
> >> Institute for Environment and Sustainability (IES)
> >> Via Fermi, 2749
> >> I-21027 Ispra (VA) - Italy - TP 261
> >> Tel. +39 0332 78 3600
> >> margherita.di-leo at jrc.ec.europa.eu
> >> Disclaimer: The views expressed are purely those of the writer and may
> not
> >> in any circumstance be regarded as stating an official position of the
> >> European Commission.
Best regards,
Via Fermi, 2749
Disclaimer: The views expressed are purely those of the writer and may not
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141002/ce78ad8b/attachment-0001.html>
