[GRASS-user] Grass70 win7 r.basin
Markus Neteler
neteler at osgeo.org
Thu Oct 2 14:26:15 PDT 2014
José,
On Thu, Oct 2, 2014 at 3:08 PM, José Anderson
<joseandersonbatista at gmail.com> wrote:
> Markus,
> thanks for clarifying. Is that just a Windows issue or r.stream.stats (plus
> other r.stream.*?) is missing on other platforms?
That's on all platforms for GRASS 7.0.svn. The code is there, it
"just" needs to be better tested and fixed as needed.
To start, compare it to what r.watershed calculates.
> In grass 6 r.basin works well so its dependences.
> So in grass7 as r.stream.stats (r.stream.order and r.stream.distance also?)
> are not yet done and are not addons, r.basin will not work.
Right for 7.0.svn.
> Could you let me know a schedule for fixing (or just in case other contact)?
Volunteers needed. Note that in *trunk* (GRASS 7.1.svn) all tools are
enabled. You may try that.
Markus
PS: If you self compile (not that hard on many platforms, see
http://grasswiki.osgeo.org/wiki/Compile_and_Install ) then you can
just change into the respective directory and run "make" to get the
command compiled for testing if you are on 7.0.svn.
