[GRASS-user] Gauss filter in r.neighbors
Wed Oct 8 01:56:53 PDT 2014
Martin Album Ytre-Eide wrote:
> (maybe there is a problem in r.neighbors for grass 6.4.4?)
Yes:
Markus Metz wrote:
> There is no problem with the Gaussian filter, but a problem with the
> output map type of r.neighbours in G64: the output type is in G64 the
> same like the input type, whereas in G7 the output type depends on the
> chosen function. That means, if you use r.neighbours method=average in
> G64 with a CELL map, the output is also CELL.
If you need it to work with 6.x, convert the input to FCELL/DCELL
first (with e.g. r.mapcalc "output = float(input)").
