[GRASS-user] my first script
Johannes Radinger
johannesradinger at gmail.com
Sun Oct 12 22:43:34 PDT 2014
It seems to raise an error related to the flag(s) you are specifying in oneof your grass modules you are using in your script. Flags in grass python scripts should be used like: flags="a" or for two flags: flags="ab". Note this does not need a "-" like in the bash command.
Best,
/johannes
-------- Original message --------
Date: 13/10/2014 02:44 (GMT+01:00)
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] my first script
Hi all,
I have my first script in python for grass
but when I launch it on windows vista for grass 6.4.2 in quantum gis
I have this output:
File "C:\PROGRA~1\QUANTU~3\apps\grass\grass-6.4.2\etc\pyth
on\grass\script\core.py", line 189, in run_command
ps = start_command(*args, **kwargs)
on\grass\script\core.py", line 167, in start_command
args = make_command(prog, flags, overwrite, quiet,
verbose, **options)
on\grass\script\core.py", line 124, in make_command
raise ScriptError("'-' is not a valid flag")
grass.script.core.ScriptError: "'-' is not a valid flag"
someone know this problem?
thanks in advance
Giuliano
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141013/d5af48cb/attachment.html>
