[GRASS-user] Categories in new layers of vector maps
Johannes Radinger
johannesradinger at gmail.com
Mon Oct 13 01:18:17 PDT 2014
I am slightly confused about creating new layers for vector maps and adding
a category value.
I want to add a layer and subsequently I want to use v.what.rast to query a
raster map and update
that layer. Hence, I need categories in the new layer. However, it seems
that adding a new table and connect it to a specific layer (v.db.addtable)
does not create/update the category column (in GRASS 71, trunk):
Here an example for the NC-dataset:
v.db.addtable map=firestations at PERMANENT layer=2
DB settings already defined, nothing to do
Reading features...
Updating database...
0 categories read from vector map (layer 2)
0 records updated/inserted (layer 2)
And when I try to manually update the category I am also not successful:
v.to.db map=firestations at PERMANENT layer=2 option=cat columns=cat
Reading features...
Maybe I just got something wrong?
The map "firestations at PERMANENT" has categories (stored in layer 1)
v.category input=firestations at PERMANENT option=report
Layer/table: 1/firestations
type count min max
point 71 1 71
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 71 1 71
v.category complete. 0 features modified.
Any suggestions?
best,
Johannes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141013/0a64cc6c/attachment.html>
