[GRASS-user] Possible to use vector attribute for r.carve's depth parameter
maning sambale
emmanuel.sambale at gmail.com
Mon Oct 13 02:50:08 PDT 2014
I have a series of vector polygon layer where there is an attribute
for estimated depth of the rivers/streams. I want to use this in
r.carve [0] to improve the river/stream channel of my DEM.
As I understand it, r.carve [0] only uses a single float value to
carve the stream channel.
Instead of looping a series of r.carve run for each depth attribute,
is it possible to just use the attribute of the vector polygon?
Thanks!
[0] http://grass.osgeo.org/grass70/manuals/r.carve.html
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
