[GRASS-user] Upper case letters for defining columns via v.db.addtable
Johannes Radinger
johannesradinger at gmail.com
Mon Oct 13 04:01:19 PDT 2014
Hi Helmut,
v.db.addcolumn is also working here.
Can you please test v.db.addtable with columns specified. This module does
not work correctly in my case.
/Johannes
On Mon, Oct 13, 2014 at 11:44 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> > a quick test here with sqlite as db-backend:
> also tested with dbf as db-backend:
> v.db.addcolumn --verbose map=mybusstopdbf at g7 columns=My_COL4 integer
> Adding column <My_COL4> to the table
> db.columns table=mybusstopdbf
> cat
> ROUTES
> UPDATED
> STREET_1
> STREET_2
> CAMPUS
> SHELTER
> BENCHES
> DISPLAY_MP
> SIGNS
> RECEPTACLE
> COMMENT_
> ID
> X
> Y
> Latitude
> Longitude
> Map_Size
> Time_Pt
> WWTm_pt
> GoTri_Name
> MDTm_Pt
> My_COL4
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/Upper-case-letters-for-defining-columns-via-v-db-addtable-tp5167120p5167161.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141013/7e0aef47/attachment.html>
