[GRASS-user] Problems with r.viewshed
Markus Neteler
neteler at osgeo.org
Mon Oct 13 12:24:45 PDT 2014
just for the record: I tried and did not have a problem:
GRASS 7.0.0svn (latlong):~ > r.viewshed -b input=srtmv4_spain
output=visPort coordinates=-3.74034324324,42.5352702703 obs_elev=9
tgt_elev=1.75 max_dist=30000
Computing events...
100%
Computing visibility...
100%
Writing output raster map...
100%
GRASS 7.0.0svn (latlong):~ > d.mon wx0
GRASS 7.0.0svn (latlong):~ > d.rast srtmv4_spain
100%
GRASS 7.0.0svn (latlong):~ > d.rast visPort
100%
--> looks ok.
Then I tried with a large computational region:
GRASS 7.0.0svn (latlong):~ > g.region n=50 s=30 w=-20 e=20 -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 50N
south: 30N
west: 20W
east: 20E
nsres: 0:00:30
ewres: 0:00:30
rows: 2400
cols: 4800
cells: 11520000
ERROR: option <output>: <visPort> exists.
tgt_elev=1.75 max_dist=30000 --o
Intermediate files will not be deleted in case of abnormal termination.
Intermediate location:
/home/neteler/grassdata/latlong/neteler/.tmp/oboe.localdomain/929.0
To save space delete these files manually!
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
Start sweeping.
Computing events...
100%
Initialize sweepline...
100%
Determine visibility...
100%
Sweeping done.
Saving grid to <visPort>
--> also fine.
I am using a 64bit Linux computer (Fedora 20), are you also on 64bit?
Markus
