[GRASS-user] Fwd: my first script
Giuliano Urgeghe
giuliano.u at gmail.com
Mon Oct 13 15:17:26 PDT 2014
---------- Forwarded message ----------
Date: 2014-10-13 23:53 GMT+02:00
Subject: Re: [GRASS-user] my first script
To: Johannes Radinger <johannesradinger at gmail.com>
Cc: grass-user at lists.osgeo.org
thanks for your help.
At moment I have another problem
in my script I have this line:
# grass.run_command('v.in.lines', overwrite=True, input =
output_esond_txt , output = output_esond_gis, fs='|')
grass.run_command('v.in.ascii', overwrite=True, format= 'point',
fs='|', input = output_esond_txt, output = output_esond_gis )
output is:
"output" non Š riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
why?
I have made many attempts whith grass6.4.2 grass6.4.3 grass6.4.4
in windows Vista
you know the problem?
thanks in advance
Giuliano
2014-10-13 7:43 GMT+02:00 Johannes Radinger <johannesradinger at gmail.com>:
> Hi,
> It seems to raise an error related to the flag(s) you are specifying in
> oneof your grass modules you are using in your script. Flags in grass
> python scripts should be used like: flags="a" or for two flags: flags="ab".
> Note this does not need a "-" like in the bash command.
> Best,
> /johannes
> -------- Original message --------
> From: Giuliano Urgeghe <giuliano.u at gmail.com>
> Date: 13/10/2014 02:44 (GMT+01:00)
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] my first script
> Hi all,
> I have my first script in python for grass
> but when I launch it on windows vista for grass 6.4.2 in quantum gis
> I have this output:
> File "C:\PROGRA~1\QUANTU~3\apps\grass\grass-6.4.2\etc\pyth
> on\grass\script\core.py", line 189, in run_command
> ps = start_command(*args, **kwargs)
> on\grass\script\core.py", line 167, in start_command
> args = make_command(prog, flags, overwrite, quiet,
> verbose, **options)
> on\grass\script\core.py", line 124, in make_command
> raise ScriptError("'-' is not a valid flag")
> grass.script.core.ScriptError: "'-' is not a valid flag"
> someone know this problem?
> thanks in advance
> Giuliano
Ing. Giuliano Urgeghe
Via Prunizzedda 61 - 07100 Sassari
tel. 3283268186
Cerca di non inviarmi files .doc, .xls, .ppt, .dwg
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141014/e807843c/attachment.html>
