[GRASS-user] v.in.geonames not importing txt file in GRASS 7.0.0beta3 Windows
RichardCooper
richtcooper at hotmail.com
Wed Oct 15 06:41:15 PDT 2014
For reference, my system:
(Wed Oct 15 20:24:41 2014) Command finished (1 sec)
System Info
GRASS version: 7.0.0beta3
GRASS SVN Revision: 61541
Build Date: 2014-08-06
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1
I also tried with geonames CZ.txt, as follows:
v.in.geonames --overwrite input=C:\Users\rcooper\CZ.txt output=czgeonames
Converting 21931 place names...
cat: =0: No such file or directory
cat: output=czgeonames: No such file or directory
cat: y=5: No such file or directory
cat: input=C:\Users\rcooper\grassdata7/chula_4326/asiapoptha
i/.tmp/unknown/1804.0: No such file or directory
cat: columns=geonameid integer,name varchar(200),asciiname
varchar(200),alternatename varchar(4000),latitude double
precision,longitude double precision,featureclass
varchar(1),featurecode varchar(10),countrycode
varchar(2),cc2 varchar(60),admin1code varchar(20),admin2code
varchar(20),admin3code varchar(20),admin4code
varchar(20),population integer,elevation varchar(5),gtopo30
integer,timezone varchar(50),modification date: File or path
name too long
Description:
Creates a vector map from an ASCII points file or ASCII
vector file.
Keywords:
vector, import, ASCII
Usage:
v.in.ascii [-zentbr] input=name output=name [format=string]
[separator=character] [skip=value] [columns=string]
[x=value]
[y=value] [z=value] [cat=value] [--overwrite] [--help]
[--verbose]
[--quiet]
Flags:
-z Create 3D vector map
-e Create a new empty vector map and exit. Nothing is
read from input.
-n Don't expect a header when reading in standard format
-t Do not create table in points mode
-b Do not build topology in points mode
-r Only import points falling within current region
(points mode)
--o Allow output files to overwrite existing files
--h Print usage summary
--v Verbose module output
--q Quiet module output
Parameters:
input Name of input file to be imported
'-' for standard input
output Name for output vector map
format Input file format
options: point,standard
default: point
point: simple x,y[,z] list
standard: GRASS vector ASCII format
separator Field separator
Special characters: pipe, comma, space, tab,
newline
default: pipe
skip Number of header lines to skip at top of input
file (points mode)
default: 0
columns Column definition in SQL style (points mode)
For example: 'x double precision, y double
precision, cat int, name varchar(10)'
x Number of column used as x coordinate (points
mode)
First column is 1
default: 1
y Number of column used as y coordinate (points
mode)
First column is 1
default: 2
z Number of column used as z coordinate (points
mode)
First column is 1. If 0, z coordinate is not
used
default: 0
cat Number of column used as category (points
mode)
First column is 1. If 0, unique category is
assigned to each row and written to new column 'cat'
default: 0
ERROR: Required parameter <input> not set:
(Name of input file to be imported)
ERROR: Required parameter <output> not set:
(Name for output vector map)
ERROR: Vector map <czgeonames> not found
(Wed Oct 15 20:29:34 2014) Command finished (8 sec)
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-geonames-not-importing-txt-file-in-GRASS-7-0-0beta3-Windows-tp5166832p5167650.html
Sent from the Grass - Users mailing list archive at Nabble.com.
