[GRASS-user] problem to install grass70 on ubuntu 12.04
Pedro Venâncio
pedrongvenancio at gmail.com
Sun Oct 19 16:02:15 PDT 2014
Hi Rashad,
You managed to check this? I continue with the same problem:
g.version -g
version=7.0.0svn
date=2014
revision=
build_date=2014-10-18
build_platform=i686-pc-linux-gnu
Thanks!
Best regards,
Pedro
2014-10-07 12:19 GMT+01:00 Rashad M <rashadkm at gmail.com>:
> Markus,
> So far, I had setup debian files repository but builds are failing. I will
> check again this weekend.
> On Fri, Oct 3, 2014 at 12:29 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi again,
>> On Fri, Oct 3, 2014 at 8:47 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> > Hi Pedro, Ubuntu'ers,
>> > On Fri, Oct 3, 2014 at 12:56 AM, Pedro Venâncio
>> > <pedrongvenancio at gmail.com> wrote:
>> >> Hi Markus,
>> >> GRASS 7.0.0 (pinhel):~ > g.version -g --v
>> >> version=7.0.0svn
>> >> date=2014
>> >> revision=
>> > --> this should not be empty.
>> >> build_date=2014-10-02
>> >> I just installed GRASS 7.0.0~ppa~2~revno-30939~ubuntu12.04.1 from ppa.
>> > I suspect that the absent version number is causing the issue. Since
>> > it was AFAIK solved time ago, this may indicate that the packaged
>> > version in the PPA is outdated.
>> Here is the related (solved) ticket:
>> http://trac.osgeo.org/grass/ticket/2351
>> and the needed change which appears to be lacking in the current Ubuntu
>> built:
>> http://trac.osgeo.org/grass/changeset/61683
>> BUT: apparently the Ubuntu package is continuously updated from SVN:
>> https://code.launchpad.net/~grass/grass/releasebranch_7_0
>> Rashad, may you please check if GRASS
>> 7.0.0~ppa~2~revno-30939~ubuntu12.04.1 from PPA is containing the
>> latest release branch updates?
>> thanks
>> Markus
> Take care
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141020/36507d9f/attachment.html>
