[GRASS-user] Loading JSON data in GRASS
Arighna
roy.arighna at gmail.com
Mon Oct 20 19:38:21 PDT 2014
Hi Vaclav,
I have loaded the point in GRASS. But the attributes are not loaded successfully. I am posting one sample data. Could you please help me finding what is wrong with the data. Or maybe I am going wrong with the loading process.
"type": "Point",
"coordinates": [50.922759,-90.089954],
"current_conditions":
"air_temp":{"unit":"F","value":32.0},
"cloud_cover":{"unit":"%","value":92.8},
"descriptors":
"cloud_cover_descriptor":{"code":20500,"icon":"http://icons.clearpathapis.com/en-us/style1/v1/128/cover_cloudy.png","text":"Cloudy"},
"precipitation_descriptor":{"code":61100,"icon":"http://icons.clearpathapis.com/en-us/style1/v1/128/precip_flurries.png","text":"Flurries"},
"visibility_obstruction_descriptor":{"code":10500,"icon":"http://icons.clearpathapis.com/en-us/style1/v1/128/error_none.png","text":"None"},
"weather_descriptor":{"code":61100,"icon":"http://icons.clearpathapis.com/en-us/style1/v1/128/precip_flurries.png","text":"Flurries"},
"wind_direction_descriptor":{"code":51800,"icon":"http://icons.clearpathapis.com/en-us/style1/v1/128/direction_w.png","text":"West"}
"dew_point":{"unit":"F","value":32.0},
"ice_acc_last_hour":{"unit":"in","value":0.0},
"liquid_acc_last_hour":{"unit":"in","value":0.0},
"msl_pressure":{"unit":"mb","value":994.0},
"precip_acc_last_hour":{"unit":"in","value":0.002},
"relative_humidity":{"unit":"%","value":91.0},
"snow_acc_last_hour":{"unit":"in","value":0.01},
"station_pressure":{"unit":"mb","value":946.0},
"u_wind_speed":{"unit":"mph","value":4.8},
"v_wind_speed":{"unit":"mph","value":0.9},
"valid_time_end":1412667600.0,
"valid_time_start":1412664000.0,
"visibility":{"unit":"mi","value":10.0},
"wind_direction":{"unit":"degrees","value":260.0},
"wind_speed":{"unit":"mph","value":7.0}
Thanks in advance
Arighna
Sent: Monday, October 06, 2014 10:28 AM
To: 'Vaclav Petras'
Subject: RE: [GRASS-user] Loading JSON data in GRASS
Hi Vaclav,
I have found the module and found GeoJSON in there. I will try to load the data and will definitely post you once get success.
Arighna
From: Vaclav Petras [ <mailto:wenzeslaus at gmail.com> mailto:wenzeslaus at gmail.com]
Sent: Sunday, October 05, 2014 10:56 PM
To: Arighna
Cc: GRASS user list; Moritz Lennert
Subject: Re: [GRASS-user] Loading JSON data in GRASS
here is a basic answer to start with.
On Sun, Oct 5, 2014 at 8:44 PM, Arighna <roy.arighna at gmail.com <mailto:roy.arighna at gmail.com> > wrote:
Hi everybody,
I want to load GeoJSON data in GRASS. I am totally unware of the process. Could anybody please help me to do that?
I never tried GeoJSON but with recent enough GRASS GIS and GDAL/OGR, you can use v.in.ogr module (module for import of vector data using OGR).
You can use
v.in.ogr -f
to list all available formats. For me it gives "GeoJSON (rw): GeoJSON".
Something like:
v.in.ogr dsn=/path/to/data/file.json output=grass_vector_map
should work. I don't know how it is with layers and features but you will see I guess.
Let us know if it work and if you have any problems.
Vaclav
Thanks & Regards
Arighna Roy
grass-user mailing list
grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141020/2560809b/attachment.html>
