[GRASS-user] python error starting grass70 in ubuntu 12.04
Javier Martínez-López javi.martinez.lopez at gmail.com
Thu Oct 30 03:14:23 PDT 2014
...ok, it is working now creating a new user following the
instructions on:
http://www.spatial-ecology.net/dokuwiki/doku.php?id=wiki:install_linux
Cheers,
Javier
On Thu, Oct 30, 2014 at 8:13 AM, Javier Martínez-López
<javi.martinez.lopez at gmail.com> wrote:
> Dear all,
> I am getting this python error when I try to start grass70 in an
> ubuntu 12-04 'dockerized' virtual machine (see
> https://registry.hub.docker.com/u/javimarlop/ubuntugis-docker/dockerfile/
> for more info and details):
> A) As root:
> root at bfc38ad6d394:/# grass70 -text
> Traceback (most recent call last):
>   File "/usr/bin/grass70", line 1150, in <module>
>     check_shell()
>   File "/usr/bin/grass70", line 771, in check_shell
>     sh = os.path.basename(os.getenv('SHELL'))
>   File "/usr/lib/python2.7/posixpath.py", line 112, in basename
>     i = p.rfind('/') + 1
> AttributeError: 'NoneType' object has no attribute 'rfind'
> B) As a different user:
> root at bfc38ad6d394:/# su javier
> javier at bfc38ad6d394:/$ grass70 -text
>   File "/usr/bin/grass70", line 1159, in <module>
>     set_paths()
>   File "/usr/bin/grass70", line 367, in set_paths
>     if sys_man_path:
> UnboundLocalError: local variable 'sys_man_path' referenced before assignment
> Python version is 2.7.3. and grass70 was installed using the
> grass-devel ppa. Does anyone have a clue?
> Thank you very much and cheers,
> Javier
