[GRASS-user] grass gis 6.4.4 i.atcorr exe problem
Markus Neteler
neteler at osgeo.org
Thu Oct 30 04:09:36 PDT 2014
On Thu, Oct 30, 2014 at 6:32 AM, kameswari devi <kams.devi at gmail.com> wrote:
> hello all,
> i have compiled grass 6.4.4 on windows. i.atcorr is th module required
> for us. i have to customize it for IRS liss4 sensor.
If you have the filter functions for the IRS liss4 sensor we can add
that to i.atcorr.
> so for landsat
> data i have tested by giving the parameters to the exe created after
> compilation. but i am not sure about the parameters and whether it is
> working properly. i have set environment variables gisbase and gisrc
> also. but it was mentioning "no module found named grass.script" can
> any one tell me how to correct arguments to pass i.atcorr..
> parameters given are: i.atcorr -r -a -o lsat7_2002_40_rad
> ialt=elevation icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr as shown
> in the link grass.osgeo.org/grass65/manuals/i.atcorr.html.
Maybe this page can help you:
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
Markus
