[GRASS-user] g.gui.animation fails at launching
Anna Petrášová kratochanna at gmail.com
Thu Oct 30 05:38:47 PDT 2014
On Thu, Oct 30, 2014 at 5:26 AM, Annalisa Minelli <annagrass6 at gmail.com>
wrote:
> Hi all,
> I'm experiencing a problem in launching g.gui.animation..
> wich doesn't load and it returns me the following error:
> "Error in atexit._run_exitfuncs"
> ..here the complete output: http://pastebin.com/FwMQa1jF
Hm, not sure when this got broken. For now, you can edit file
gui/wxpython/animation/g.gui.animation.py and instead of last line
GuiModuleMain(main)
use
main()
and recompile. That should fix it, but it will block your command line
unless you use &
Anna
> I compiled GRASS yesterday (checking out the grass70 release version), it
> seemed fine and I used this configure:
> ./configure --with-proj-share=/usr/local/share/proj/ --with-python
> --with-cxx --with-freetype --with-freetype-includes=/usr/include/freetype2/
> --with-includes=/usr/local/lib --with-wxwidgets --enable-largefile
> --enable-64bit --with-sqlite --with-sqlite-includes=/usr/include/
> --with-opengl --with-postgres
> --with-postgres-includes=/usr/include/postgresql/
> --with-tcltk-includes=/usr/include/tcl8.5 --with-gdal --with-netcdf
> --with-ffmpeg --with-motif --with-geos --with-odbc --with-mysql
> --with-mysql-includes=/usr/include/mysql/
> Many thanks,
> Annalisa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141030/10ced5e6/attachment.html>
