[GRASS-user] g.gui.animation fails at launching
Anna Petrášová kratochanna at gmail.com
Fri Oct 31 14:25:34 PDT 2014
On Thu, Oct 30, 2014 at 10:48 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Oct 30, 2014 at 8:38 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Thu, Oct 30, 2014 at 5:26 AM, Annalisa Minelli <annagrass6 at gmail.com>
>> wrote:
>>> Hi all,
>>> I'm experiencing a problem in launching g.gui.animation..
>>> wich doesn't load and it returns me the following error:
>>> "Error in atexit._run_exitfuncs"
>>> ..here the complete output: http://pastebin.com/FwMQa1jF
>> Hm, not sure when this got broken. For now, you can edit file
>> gui/wxpython/animation/g.gui.animation.py and instead of last line
> the error is caused by r62374
> http://trac.osgeo.org/grass/changeset/62374/grass/trunk
> I don't say this commit is wrong, maybe the GuiModuleMain is wrong.  Any
> opinion? I remember GuiModuleMain had some problems on Mac, too.
If there won't be any progress on this soon, I will probably stop using the
process forking in GuiModuleMain for g.gui.* modules. It seems that it
brings a lot of problems and typing & after the command does the same
without any problems. On Windows, we can't use it anyway and I remember
some crashing on Mac, too. So let's have it less convenient but more stable.
Anna
> Anna
>> GuiModuleMain(main)
>> use
>> main()
>> and recompile. That should fix it, but it will block your command line
>> unless you use &
>> Anna
>>> I compiled GRASS yesterday (checking out the grass70 release version),
>>> it seemed fine and I used this configure:
>>> ./configure --with-proj-share=/usr/local/share/proj/ --with-python
>>> --with-cxx --with-freetype --with-freetype-includes=/usr/include/freetype2/
>>> --with-includes=/usr/local/lib --with-wxwidgets --enable-largefile
>>> --enable-64bit --with-sqlite --with-sqlite-includes=/usr/include/
>>> --with-opengl --with-postgres
>>> --with-postgres-includes=/usr/include/postgresql/
>>> --with-tcltk-includes=/usr/include/tcl8.5 --with-gdal --with-netcdf
>>> --with-ffmpeg --with-motif --with-geos --with-odbc --with-mysql
>>> --with-mysql-includes=/usr/include/mysql/
>>> Many thanks,
>>> Annalisa
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141031/e80406f3/attachment.html>
