[GRASS-user] OSX Yosemite - GRASS 6.4 stopped working
Thomas Adams tea3rd at gmail.com
Mon Sep 1 14:24:52 PDT 2014
Carlos,
Yes, the 'normal' GRASS TERM window. My apologies; I did not mean to use
Control-C during the GRASS launch, but -AFTER- the error appears. What I
sent you was from your original post. Interestingly, when I try to launch
GRASS on my Mac, I got the error I often see, but *your* error message is
very different from *mine*.
You get:
/Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh
The error I get has the path:
/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh
See what happens if you use my path, above. If you have GRASS in your
Applications folder, the path I have should work. I have no idea why yours
is so different. No wonder GRASS is not launching. BTW, just now, when I
used my path above, GRASS just launched just fine for me.
Best,
Tom
On Mon, Sep 1, 2014 at 12:54 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> Thanks Tom,
> but I couldn't replicate your workaround. You mean the term window that
> opens when GRASS is started "normally" (from dock or Application)?
> If so, mine was a bit fast and I couldn't hit ctrl-C fast enough to stop
> it
> in a normal term window, just pasting the line you provided also returned
> me the same error as before (No such file or directory)
> best
> Carlos
> On Mon, Sep 1, 2014 at 1:48 PM, Thomas Adams <tea3rd at gmail.com> wrote:
>> Carlos,
>> I have seen the same thing; here is what I figured-out as a brute force
>> work-around:
>> (1) in the TERM window that pops-up do Control-C
>> (2) copy and paste:
>> (or the GRASS 7 equivalent)
>> (3) <RETURN>
>> This works every time I get this + it seems to temporarily 'fix' the
>> problem...
>> Cheers!
>> Tom
>> On Mon, Sep 1, 2014 at 11:00 AM, Carlos Grohmann <
>> carlos.grohmann at gmail.com> wrote:
>>> Hi all
>>> I'm running OS X Yosemite Beta, and my GRASS install just stopped
>>> working. It was running fine until last week, but now I can't open it, with
>>> the following error msg:
>>> Last login: Mon Sep  1 11:37:04 on ttys002
>>> '/Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh';
>>> exit
>>> GuanoBookPro:~ guano$
>>> exit
>>> -bash:
>>> /Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh:
>>> logout
>>> [Process completed]
>>> The same happens with GRASS-7
>>> I don't recall updating anything (maybe some automatic update happened
>>> in the background), and I already tried to reinstall GRASS.
>>> Trying to run grass.sh from /Applications/GRASS-6.4.app/Contents/MacOS/
>>> will not work as well, first with a Gis_set Error about the splash screen
>>> (should a missing splash screen gif cause an error on startup??), and after
>>> it, with a python error:
>>> Starting GRASS ...
>>> Traceback (most recent call last):
>>>   File "./etc/wxpython/gis_set.py", line 1003, in <module>
>>>     GRASSStartUp = StartUp(0)
>>>   File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line
>>> 8631, in __init__
>>>     self._BootstrapApp()
>>>   File
>>> 8196, in _BootstrapApp
>>>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>   File "./etc/wxpython/gis_set.py", line 978, in OnInit
>>>     StartUp = GRASSStartup()
>>>   File "./etc/wxpython/gis_set.py", line 95, in __init__
>>>     versionFile = open(os.path.join(globalvar.ETCDIR, "VERSIONNUMBER"))
>>> IOError: [Errno 2] No such file or directory: './etc/VERSIONNUMBER'
>>> Error in GUI startup. If necessary, please
>>> report this error to the GRASS developers.
>>> Switching to text mode now.
>>> Hit RETURN to continue...
>>> So, I went and reinstall wxpython, but again with no success.
>>> any help at this point is very much welcome
>>> best
>>> Carlos
>>> Prof. Carlos Henrique Grohmann
>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> http://carlosgrohmann.com
>>> http://orcid.org/0000-0001-5073-5572
>>> ________________
>>> Can’t stop the signal.
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> ________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140901/a3b5c6d3/attachment.html>
