[GRASS-user] Topological Trouble
James Keener
jim at jimkeener.com
Mon Sep 1 16:26:03 PDT 2014
Thanks for replying Markus,
> Note that their projection is in meters, while...
>>>> I am using the following shapefiles in SRID 2272 (NAD83 / Pennsylvania
>>>> South (ftUS)):
> ... your's is in US feet (http://epsg.io/2272).
> This affect the threshold you use below:
I know. For testing purposes it seemed to be reasonable, though
(increments of 1000 ft. For my final map I'll probably do 1/4mi, 1/2mi,
3/4mi, and 1mi increments).
>>>>> v.net input=roads points=stops output=network operation=connect
>>>>> thresh=500
> Note that the threshold is specified in map units (so, here feet in your case).
I spot checked a lot of the bus stops, and they appeared to be connected
to the road graph. FWIW. The TIGER road maps do appear to make
intersections overlap, but don't put a point that all the adjoining
roads connect to. (This brings up something I was going to worry about
later: bridges vs intersections?)
> Sidenote: in GRASS GIS 7 the module is a bit more advanced:
> http://grass.osgeo.org/grass70/manuals/v.net.html
> Perhaps (guessing, I didn't have time to test your data), the initial
> threshold makes the difference?
I'll have to give GRASS 7 a shot:) (GRASS 6 is what was in the repo I
was using).
I'm completely new at this so the biggest problem for me is not know
exactly where to look when something isn't working.
Thanks again for your input!
Jim
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140901/38ca22c8/attachment.pgp>
