[GRASS-user] help with r.series
Glynn Clements
glynn at gclements.plus.com
Thu Sep 4 13:41:39 PDT 2014
Rajat Nayak wrote:
> I have created a few list using g.mlist command in grass7. Each list has a
> few raster layers. For example; FILE2000 has lists of all monthly layers
> for the year 2000, FILE2001 has layers for 2001...so on.
> Now I want to create one layer each for each of these lists (each year). I
> can use "r.series" command with method="average", to get a layer with
> averaged values across all the months for a particular year. Now I have 14
> such lists corresponding to 14 years and do not want to repeat the process
> for each year. Is there a way to automate this process using grass prompt?
> I don't want to move to R, would like to complete all the work in GRASS.
bash:
for file in FILE20?? ; do
r.series file=$file output=output${file#file} method=average
done
Python:
import os
import grass.script as grass
for file in os.listdir('.'):
if not file.startswith('FILE20'):
continue
output = 'output' + file[4:]
grass.run_command('r.series', file=file, output=output,
method='average')
