[GRASS-user] Add-on compilation errors in GRASS 7
Martin Landa
landa.martin at gmail.com
Wed Sep 10 00:23:08 PDT 2014
2014-09-10 8:06 GMT+02:00 Hermann Peifer <peifer at gmx.eu>:
> I assume that at some point, there will be a full-size modules.xml file for
> grass7, i.e. comparable to http://grass.osgeo.org/addons/grass6/modules.xml
> Any idea when this will be?
hm, it's broken again, strangely only when launched via cronjobs (this
happens after I reinstalled the server where it's running). Manually
launched scripts simply work. Will fix it manually right now, and I
will try to find out what is wrong with cronjob which should work in
the same way as launching scripts manually.
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
