[GRASS-user] Add-on compilation errors in GRASS 7
Martin Landa
landa.martin at gmail.com
Wed Sep 10 02:46:30 PDT 2014
2014-09-10 10:11 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> launched scripts simply work. Will fix it manually right now, and I
>> will try to find out what is wrong with cronjob which should work in
> it's back. I will test cronjobs and try to fix the real problem behind. Martin
the problem was that the path defined by crontab lacked
`/usr/local/bin`. I have fixed that, hopefully the next call (this
night) will be finally OK.
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
