[GRASS-user] question about r.info
m roy
royroge at outlook.com
Fri Sep 12 06:17:36 PDT 2014
That’s all right, thanks !
Da: Hermann Peifer
Data invio: giovedì 11 settembre 2014 19.06
A: m roy
On 2014-09-11 14:10, m roy wrote:
> Thank’s for the replay Hermann,
> this is not the case AFAIK because i generated the map using r.mapcalc
> with region and MASK properly set …
Just to be on the safe side, you could do:
r.mask -r
g.region -p rast=myMap
r.describe myMap
r.stats -c myMap
Hermann
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140912/b5a8b583/attachment.html>
