[GRASS-user] GRASS7: problems with WMS
Hermann Peifer peifer at gmx.eu
Thu Sep 18 22:12:04 PDT 2014
As far as I tried out: the error occurs for any WMS in any projection,
including all the built-in servers. It looks like no other GRASS7 user
ever had the same issue, which is surprising. From the error message, I
assume that soemthing is going systematically wrong with the numbering
of the files in the .tmp directory.
I am currently trying with layer: "WMS Global Mosaic, pan sharpened"
from the built-in server list: http://onearth.jpl.nasa.gov/wms.cgi
The result is:
ERROR 4: `/home/peifer/grassdata/wgs84/PERMANENT/.tmp/whitefish/32754.4'
does not exist in the file system, and is not recognised as a supported
dataset name.
File 32754.4 does indeed not exist. See below.
Hermann
[GRASS:PERMANENT]> file .tmp/whitefish/*
.tmp/whitefish/32754.0.ppm: Netpbm PPM "rawbits" image data
.tmp/whitefish/32754.10:    XML  document text
.tmp/whitefish/32754.11:    XML  document text
.tmp/whitefish/32754.5:     XML  document text
.tmp/whitefish/32754.6:     XML  document text
.tmp/whitefish/32754.7:     XML  document text
.tmp/whitefish/32754.8:     HTML document text
.tmp/whitefish/32754.9:     XML  document text
On 2014-09-18 22:31, Štěpán Turek wrote:
> Hi Hermann,
> would be possible to send me the WMS service URL you are trying to connect?
> Best
> Stepan
> ---------- Původní zpráva ----------
> Od: Hermann Peifer <peifer at gmx.eu>
> Komu: GRASS user list <grass-user at lists.osgeo.org>
> Datum: 18. 9. 2014 19:24:44
> Předmět: Re: [GRASS-user] GRASS7: problems with WMS
>     Just to add that I continue trying to load the WMS, without success,
>     though. My current error message is:
>     ERROR 4: `/home/peifer/grassdata/laea/test/.tmp/whitefish/17189.4' does
>     dataset name.
>     When looking into .tmp/whitefish, I see a series of 17189.* files, but
>     obviously not 17189.4:
>     [GRASS:test]> ls -l .tmp/whitefish/
>     total 1184
>     -rw-r--r-- 1 peifer mtr 1144239 Sep 18 19:18 17189.0.ppm
>     -rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.10
>     -rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.11
>     -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.5
>     -rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.6
>     -rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.7
>     -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.8
>     -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.9
>     On 2014-09-18 8:41, Hermann Peifer wrote:
>      > Hi All,
>      > I am trying to load a WMS using GRASS7, which I compiled from
>      > svn/release branch.
>      > Connecting to the WMServer, selecting and adding a layer works
>     fine, but
>      > I do not get any image into the map display.
>      > The GUI's Map Console reports:
>      > Unable to determine region, m.proj failed
>      > The console, from which I started the GUI says:
>      > ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12' does not exist
>     in the
>      > file system, and is not recognised as a supported dataset name.
>      > After noting the error related to region/m.proj, I tried both: to
>     load a
>      > WMS in EPSG:3035 into my LAEA location and to load another WMS in
>      > EPSG:4326 into my WGS84 location, whithout any luck.
>      > Any hints?
>      > Thanks in advance, Hermann
>     _______________________________________________
>     grass-user mailing list
>     http://lists.osgeo.org/mailman/listinfo/grass-user
