[GRASS-user] GRASS7: problems with WMS
Anna Petrášová
kratochanna at gmail.com
Fri Sep 19 06:33:29 PDT 2014
On Fri, Sep 19, 2014 at 1:12 AM, Hermann Peifer <peifer at gmx.eu> wrote:
> As far as I tried out: the error occurs for any WMS in any projection,
> including all the built-in servers. It looks like no other GRASS7 user ever
> had the same issue, which is surprising. From the error message, I assume
> that soemthing is going systematically wrong with the numbering of the
> files in the .tmp directory.
> I am currently trying with layer: "WMS Global Mosaic, pan sharpened" from
> the built-in server list: http://onearth.jpl.nasa.gov/wms.cgi
> The result is:
> ERROR 4: `/home/peifer/grassdata/wgs84/PERMANENT/.tmp/whitefish/32754.4'
> does not exist in the file system, and is not recognised as a supported
> dataset name.
I get the same, however in the gui console I also get:
WMS server error: <?xml version='1.0' encoding="UTF-8"
standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://wms.jpl.nasa.gov/exception_1_1_1.dtd ">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
This server no longer provides full WMS services!
</ServiceException>
</ServiceExceptionReport>
so this service doesn't work any more.
Anna
> File 32754.4 does indeed not exist. See below.
> Hermann
> [GRASS:PERMANENT]> file .tmp/whitefish/*
> .tmp/whitefish/32754.0.ppm: Netpbm PPM "rawbits" image data
> .tmp/whitefish/32754.10: XML document text
> .tmp/whitefish/32754.11: XML document text
> .tmp/whitefish/32754.5: XML document text
> .tmp/whitefish/32754.6: XML document text
> .tmp/whitefish/32754.7: XML document text
> .tmp/whitefish/32754.8: HTML document text
> .tmp/whitefish/32754.9: XML document text
> On 2014-09-18 22:31, Štěpán Turek wrote:
>> Hi Hermann,
>> would be possible to send me the WMS service URL you are trying to
>> connect?
>> Best
>> Stepan
>> ---------- Původní zpráva ----------
>> Od: Hermann Peifer <peifer at gmx.eu>
>> Komu: GRASS user list <grass-user at lists.osgeo.org>
>> Datum: 18. 9. 2014 19:24:44
>> Předmět: Re: [GRASS-user] GRASS7: problems with WMS
>> Just to add that I continue trying to load the WMS, without success,
>> though. My current error message is:
>> ERROR 4: `/home/peifer/grassdata/laea/test/.tmp/whitefish/17189.4'
>> does
>> dataset name.
>> When looking into .tmp/whitefish, I see a series of 17189.* files, but
>> obviously not 17189.4:
>> [GRASS:test]> ls -l .tmp/whitefish/
>> total 1184
>> -rw-r--r-- 1 peifer mtr 1144239 Sep 18 19:18 17189.0.ppm
>> -rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.10
>> -rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.11
>> -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.5
>> -rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.6
>> -rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.7
>> -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.8
>> -rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.9
>> On 2014-09-18 8:41, Hermann Peifer wrote:
>> > Hi All,
>> > I am trying to load a WMS using GRASS7, which I compiled from
>> > svn/release branch.
>> > Connecting to the WMServer, selecting and adding a layer works
>> fine, but
>> > I do not get any image into the map display.
>> > The GUI's Map Console reports:
>> > Unable to determine region, m.proj failed
>> > The console, from which I started the GUI says:
>> > ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12' does not exist
>> in the
>> > file system, and is not recognised as a supported dataset name.
>> > After noting the error related to region/m.proj, I tried both: to
>> load a
>> > WMS in EPSG:3035 into my LAEA location and to load another WMS in
>> > EPSG:4326 into my WGS84 location, whithout any luck.
>> > Any hints?
>> > Thanks in advance, Hermann
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140919/e1328503/attachment.html>
