[GRASS-user] r.patch number of input limitation?
Markus Neteler
neteler at osgeo.org
Wed Sep 24 06:21:55 PDT 2014
On Wed, Sep 24, 2014 at 2:40 PM, Robert Kuszinger <kuszinger at giscom.hu> wrote:
> Hello!
> I'm trying to patch 1393 pieces of raster images with r.patch.
> before r.patch, the projection is set as follows:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 33:00:00.5N
> south: 14:00:00.5S
> west: 75:59:59.5E
> east: 136:00:00.5E
> nsres: 0:01:00.000355
> ewres: 0:01:00.000278
> rows: 2820
> cols: 3600
> cells: 10152000
> As you see, the target mosaic is set to be a moderate resolution by setting
> es/nwres to 1 minute instead of seconds.
> I do then:
> GRASS 6.4.3 (wgs84pure):~/grassdata/import > MAPS=`g.mlist type=rast sep=,
> pat="AST*"`
> GRASS 6.4.3 (wgs84pure):~/grassdata/import > r.patch in=$MAPS out=mosaic
> WARNING: Unable to open raster map <ASTGTM2N31E096 at seasdem2>
> ERROR: One or more input raster maps not found
> How could it be? Is there a limitation on the string what r.patch is parsing
> from the command line?
It is indeed the operating system which limits the number of open
files. For Linux, it is likely 1024 files.
I have now added a note to the manual of r.patch (using those of r.series).
For a solution, see also
http://grasswiki.osgeo.org/wiki/Large_raster_data_processing#Number_of_open_files_limitation
You can increase this limit.
Hope this helps,
Markus
