[GRASS-user] Problems with r.viewshed
Luis Miguel Royo Pérez luis.miguel.royo at gmail.com
Thu Sep 25 05:11:36 PDT 2014
I'm sorry but it didn't work.
I have reinstalled the addon but it didn't work, reinstalled GRASS 6.4
and neither, then installed GRASS7 again, and appears this message:
r.viewshed -b input=Portada en inisig output=visPort
coordinates=-3.74034324324,42.5352702703 obs_elev=9 tgt_elev=1.75
max_dist=30000
Computing events...
Computing visibility...
r.viewshed: statusstructure.cpp:73: float
get_vertical_angle(Viewpoint, StatusNode, surface_type,
int): La declaración `fabs(sn.dist2vp) > 0.001' no se
cumple.
I will try in another PC.
Thank you for your time.
El 25/09/14 a las #4, Markus Neteler escribió:
> On Thu, Sep 25, 2014 at 10:35 AM, Luis Miguel Royo Pérez
> <luis.miguel.royo en gmail.com> wrote:
>> Hi everyone,
>> when I try to run r.viewshed the output shows me this:
> (in GRASS 6 it is an Addon)
>> Nodata value set to -nan
>> rows=198, cols=217, total = 42966
>> In-memory memory usage is 4298336 B (4 MB),             max mem
>> allowed=524288000 B(500MB)
>> *****  IN_MEMORY MODE  *****
>> Start sweeping.
>> Computing events ...
>> Sorting events...
>> Terminado.
>> Determine visibility...
>> cumple.
>> Anyone has a clue about what it could be happening?
>> I'm using GRASS 6.4.4 in Xubuntu 14.04.
> I have backported some fixes from GRASS 7 to the addon in GRASS 6.
> Please reinstall the addon with g.extension and try again.
>> I think I must say that a few days ago I installed GRASS 7 but I removed it
>> and reinstalled GRASS 6.4.4. Maybe is there any  incompatibility?
> No, GRASS 6 and 7 can happily live together.
> Please let us know if the updated Addon runs ok for you.
> Markus
------------ pr�xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140925/edaf5af2/attachment.html>
