[GRASS-user] 64 bit Python in GRASS 6.4.2
Orr, Andrew B.
aorr at anl.gov
Fri Sep 26 08:30:41 PDT 2014
Thanks Saber,
I already have GRASS installed, and if I recall the application you linked me to is an interface for installing GRASS? What I'm hoping for is upgrading the version of Python to 64 bit that GRASS is using.
When I open GRASS and go to the Python shell it says it's using a 32 bit version of Python 2.7.2.
I know it's a separate installation for ArcGIS to get a 64 bit version of Python installed so I was thinking that GRASS may be the same procedure?
Thanks,
-Andy
From: Saber Razmjooei [mailto:saber.razmjooei at lutraconsulting.co.uk]
Sent: Friday, September 26, 2014 10:23 AM
To: Orr, Andrew B.; grass-user at lists.osgeo.org
Subject: RE: [GRASS-user] 64 bit Python in GRASS 6.4.2
Hi Andy,
You can try this:
http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe
Cheers,
Saber
From: grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org> [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Orr, Andrew B.
Sent: 26 September 2014 15:46
To: 'grass-user at lists.osgeo.org'
Subject: [GRASS-user] 64 bit Python in GRASS 6.4.2
Hello all,
I've been working on a r.cost and r.drain python script that is using very large rasters. I've been running into some memory issues with this script due to the size of the rasters. I read about setting the amount of memory that the map can be stored in with the "percent_memory=xx" argument for r.cost, however the performance of running the script is becoming a problem (it takes too long to run for our goal).
I then started watching the Task Manager and noticed it was peaked out at less ~4 gigs of ram and I realized it's only a 32 bit version of Python installed with GRASS.
My question is: is there a compatible 64 bit version of Python for GRASS 6.4.x, and if so, how does one install it?
Thanks for your help!
-Andy
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viru ses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions<http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf> shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140926/600cd107/attachment.html>
