[GRASS-user] Solved: execGRASS("r.diversity") Done. No rasters	created (Large rasters)
    Sandra MacFadyen
    sandramf at live.co.za
    Mon Sep 29 18:24:47 PDT 2014
Dear Vaclav,
I did a quick manual test to see if the results were correct for a few 5x5 windows and yes, everything appears 100%:
# Example data from one 5x5 window
test1 = c(572,617,661,638,616,
          662,617,593,638,616,
          662,639,572,661,616,
          662,662,639,662,616,
          594,572,594,639,593)
# Calculate info needed for diversity indices
freq1 = as.data.frame(table(test1)) # Calculate frequency table
S = length(unique(test1)) # Total number of species (S)
N = length(test1) # Total number of individuals (N)
ln.S = log(S) #Natural log of species (ln S)
ln.N = log(N) # Natural log of individuals (ln N)
Pi = freq1$Freq/N # Proportion of individuals that belong to each species
Pi2 = (Pi ^ 2)
ln.pi = log(Pi)
pi.ln.pi = Pi * ln.pi
pi.ln.pi2 = (ln.pi^2)*Pi
# Calculate different diversity indices
(M = (S-1)/ln.N) # Margalef's index (M)
(i.Di = 1/sum(Pi2)) # Simpson's index [Inverse] (i.Di)
(i.Dc = 1 - (sum(Pi2))) # Simpson's index [Complement] (i.Dc) * This one calculated with r.diversity
(H = sum(pi.ln.pi)*-1) # Shannon-Wiener index (H')
(J = H/ln.S) # Pielou's index (J)
Thanks again
Cheers
Sandra
From: Vaclav Petras [mailto:wenzeslaus at gmail.com]
Sent: 18 September 2014 02:46 AM
To: Sandra MacFadyen
Cc: Markus Neteler; GRASS user list; Duccio Rocchini; Luca Delucchi
Subject: Re: [GRASS-user] Solved: execGRASS("r.diversity") Done. No rasters created (Large rasters)
On Wed, Sep 17, 2014 at 7:40 PM, Sandra MacFadyen <sandramf at live.co.za> wrote:
Dear Markus,
Excellent! Thanks to everyone for their help.
I tested r.diversity in the new revision (61840) on a raster with 12933032 cells and it took under 3 minutes to complete r.li.simpson, r.li.shannon, r.li.pielou and r.li.renyi outputs.
Amazing :)
> execGRASS("r.diversity",flags="overwrite", parameters=list(input="flow", prefix="flow_div", alpha=0.5, size=3))
> r.li.simpson complete. Raster map <flow_div_simpson_size_3.0> created.
> r.li.shannon complete. Raster map <flow_div_shannon_size_3.0> created.
> r.li.pielou complete. Raster map <flow_div_pielou_size_3.0> created.
> r.li.renyi complete. Raster map <flow_div_renyi_size_3.0_alpha_0.5>
> created.
> Done.
Thanks again and keep well.
Good to hear that. Can you say if the results are correct? I computed difference of one map before and after and it was OK. But it would be great to have more tests. Let's start with: does the result make sense?
Vaclav
Cheers
Sandra
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: 06 September 2014 05:15 AM
Cc: GRASS user list; Duccio Rocchini; Luca Delucchi
Subject: Re: [GRASS-user] execGRASS("r.diversity") Done. No rasters created (Large rasters)
Dear Sandra,
On Fri, Jun 20, 2014 at 7:49 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Jun 14, 2014 at 9:21 AM, Sandra MacFadyen <sandramf at live.co.za> wrote:
>> I am using r.diversity (GRASS GIS 7.0.0svn build 60785 win32) through
>> R (R version 3.0.2 win32) on Windows 7 64bit.
>> However, when running the same code on a larger image (cells=6746328)
>> from my own location, although it reports Done, no rasters are
>> created. If I subset the image
>> (cells=1632830) and run it again its works (see # sub2Kruger # code and results below).
>> So I'm guessing it is a memory issue?
> ... it consumes a lot of memory... will check on a bigger machine,
> perhaps a memory leak.
The assumption turned out to be right and I think we got it today!
Vaclav Petras checked it and discovered an "unfortunate" memory allocation which he fixed in r.li.* in revision http://trac.osgeo.org/grass/changeset/61812 ("r.li: fix memory handling (memory leak in avl_to_array function))".
Now r.li has become very fast, on my laptop:
GRASS 7.1.svn (nc_spm_08_grass7):~ >  g.region -p rast=lsat5_1987_10 res=10 -a ...
rows:       1355
cols:       1503
cells:      2036565
GRASS 7.1.svn (nc_spm_08_grass7):~ > time -p r.li.simpson --o input=lsat5_1987_10 at landsat conf=conf_diversity_5.0
output=lsat5_1987_div__simpson_size_5.0
r.li.simpson complete. Raster map <lsat5_1987_div__simpson_size_5.0>
created.
--> 29.32 seconds
or with a simulated higher resolution:
res=5 -aprojection: 99 (Lambert Conformal Conic) ...
rows:       2708
cols:       3005
cells:      8137540
created.
--> 227.37 seconds (used to be > 2 hours)
So, to grab this improvement for Windows, grab the version from here:
http://wingrass.fsv.cvut.cz/grass71/
(or via OSGeo4W installer). Be sure that the revision is at least
r61812 which is indicated in the file name.
Please let us know if all works to avoid that the change has any negative impact.
Tests here did not show any changes in the output except for the speed improvement and solved memory leak.
Subsequently also r.diversity should behave now.
I'll backport it to GRASS 7.0 release branch after some testing.
Markus
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140930/5f720005/attachment.html>
