[GRASS-user] i.group with patterns as name for input
umberto.minora
umberto.minora at unimi.it
Wed Apr 1 08:48:36 PDT 2015
Dear Nikos (and again Pietro, thanks)
I am trying this, but GRASS ouputs a Windows error, then the script
continues (very strange) and outputs an error:
from grass.script.core import run_command
from grass.script import parse_command
dem="khumbu_dem"
aspect= "khumbu_aspect"
slope= "khumbu_slope"
outFolder=
"D:\UMBE\PhD\Nepal\khumbu_article\shadow\r_sun_hourly\prova_hourly_shadow"
day_month=[range(1,3),range(3,5)]
for m in xrange(len(day_month)):
group_list= []
for d in day_month[m]:
run_command("r.sun.hourly",
flags="b",
elevation=dem,
aspect=aspect,
slope=slope,
start_time=0,
end_time=3,
day=d,
year=2014,
beam_rad_basename="prova"+ str(m+1)+ "_"+ str(d)) # Underscore and hour
are added to the base name for each map
group_list= parse_command("g.list",
type="raster",
pattern="prova"+ str(m+1)).keys()
run_command("i.group",
group="prova"+ str(m+1),
input=group_list)
run_command("r.out.gdal",
flags="c",
type="Byte",
input="prova"+ str(m+1),
output=outFolder+ "\prova"+ str(m+1)+ ".tif",
nodata=255)
As you can see I am using "i.group" to create a list (named "group_list")
which updates at each iteration (as you suggested in an old quesion
<http://lists.osgeo.org/pipermail/grass-user/2014-November/071197.html> I
posted). Anyway, I receive this error after the first "r.sun.hourly" loop:
File "D:\UMBE\PhD\Nepal\khumbu_article\shadow\r_sun_hourly
\prova_r-sun-hourly.py", line 32, in <module>
input=group_list)
File "C:\OSGeo4W\apps\grass\grass-7.0.0\etc\python\grass\s
cript\core.py", line 375, in run_command
return handle_errors(returncode, returncode, args,
kwargs)
cript\core.py", line 310, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['i.group', 'input=', 'group=prova1'] ended with error
Process ended with non-zero return code 255. See errors in
the (error) output.
It could be related to the fact that the option "input" of "i.group" should
be something like "a,b,c" and not "'a','b','c'" (as my variable "group_list"
is like)?
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-group-with-patterns-as-name-for-input-tp5196465p5196494.html
Sent from the Grass - Users mailing list archive at Nabble.com.
