[GRASS-user] re-order boundaries by relative position along	polyline
    Adrien André
    adrien.andre at onf.fr
    Tue Apr  7 07:44:11 PDT 2015
Dylan, Tom,
not about the main question, but to complete Tom's answer:
I had once to vectorize a raster stream network according to flow direction.
You can find here the Python script i wrote:
https://github.com/adrienandrem/r.to.vect.dir
I hope this helps.
Regards,
Adrien
Le 05/04/2015 14:48, Thomas Adams a écrit :
> Hi Dylan!
> (I'm about to start a new position — more on that later). This may help…
> I had a problem somewhat analogous to this a little while ago, where I
> needed to create a text file that, among a couple of other things,
> needed to identify the 'downstream' pixel for all grid cells within a
> basin area. I was able to do that with help here, but an issue I had was
> that the integer IDs needed to be numbered from 0-N in basically
> upstream to downstream order, but after my GRASS analysis I had IDs with
> some large number ranging to some other very large number for the IDs
> and the 'downstream IDs' (with values skipped and not in order). I got
> help writing a Perl script that uses hashes for a lookup table to relate
> the old ID to the new ID.
> Perhaps you could do something like this, starting with a new vector map
> (copy) where you could simply update the attributes using an SQL query?
> Some coding would be needed, obviously…
> Just my 2 cents…
> Cheers!
> Tom
> On Thu, Apr 2, 2015 at 6:31 PM, Dylan Beaudette
> <dylan.beaudette at gmail.com <mailto:dylan.beaudette at gmail.com>> wrote:
>     Hi,
>     Once again, I am reminded that complex spatial analysis in other
>     software
>     can usually be reduced to a couple of lines of code in GRASS-- thanks!
>     Here is a fun question. Suppose you have a set of line segments, or
>     boundaries that are the result of a digitizing process that generated
>     segments out of "order":
>           2             4              1           3
>     O---------+-----------------+------------+------O
>     'O' = start / end point
>     '+' = vertex
>     ... in this case "order" is associated with order in which records
>     appear
>     in the attribute table and the order in which segments are drawn on the
>     screen.
>     Is there a module, or set of modules that could be used to re-order the
>     segments so that the order of records in the attribute table and drawing
>     order is:
>           1             2              3           4
>     Note that I do not wan't to shuffle the linkages between geometry and
>     attributes, rather, I would like to re-order the segments and attribute
>     table according to the linear position within the set of contiguous
>     boundaries or polyline.
>     Here is an example set of lines in ASCII format, WGS84 GCS.
>     ORGANIZATION:
>     DIGIT DATE:
>     DIGIT NAME:   dylan
>     MAP NAME:
>     MAP DATE:     Thu Apr  2 11:46:34 2015
>     MAP SCALE:    1
>     OTHER INFO:
>     ZONE:         0
>     MAP THRESH:   0.000000
>     VERTI:
>     B  6 1
>      -118.71960108 36.71846736
>      -118.71946261 36.71783146
>      -118.71905508 36.71717314
>      -118.71863837 36.71610377
>      -118.71807413 36.71546352
>      -118.71786286 36.71527706
>      2     132
>     B  3 1
>      -118.7153795 36.73403608
>      -118.71537992 36.73272737
>      -118.71538933 36.73177277
>      2     133
>     B  3 1
>      -118.71536851 36.76205202
>      -118.7153724 36.7609144
>      -118.71537619 36.75980591
>      2     150
>     B  2 1
>      -118.73128842 36.69749903
>      -118.73130166 36.69760244
>      2     175
>     B  5 1
>      -118.7153944 36.73125742
>      -118.71573607 36.73044156
>      -118.71618977 36.72875872
>      -118.71651025 36.72811846
>      2     581
>     B  15 1
>      -118.71661716 36.72766138
>      -118.71660977 36.7273294
>      -118.71645785 36.72668322
>      -118.71689758 36.7261392
>      -118.71724087 36.72567564
>      -118.71747107 36.7248177
>      -118.71753527 36.72390024
>      -118.71787045 36.72307308
>      -118.71797278 36.72237579
>      -118.71781832 36.72073331
>      -118.71825483 36.72004703
>      -118.71908689 36.71948153
>      -118.71963768 36.71863545
>      2     602
>     B  8 1
>      -118.7180943 36.70872005
>      -118.71827421 36.7083356
>      -118.71841915 36.7080259
>      -118.7190169 36.70752707
>      -118.72008403 36.70694237
>      -118.72042476 36.70636815
>      -118.72049695 36.70608245
>      -118.7212077 36.70547966
>      2     604
>     B  15 1
>      -118.721692  36.70506892
>      -118.72256889 36.70442599
>      -118.72372477 36.702873
>      -118.72417965 36.70213899
>      -118.72496002 36.70190631
>      -118.72660809 36.70183505
>      -118.72765407 36.70118732
>      -118.72831767 36.70100376
>      -118.72866574 36.7007615
>      -118.72887421 36.70026501
>      -118.72998965 36.69849669
>      -118.73066541 36.69798083
>      -118.73118943 36.69770441
>      2     609
>     B  8 1
>      -118.7153867 36.75138736
>      -118.7153804 36.7500365
>      -118.7153634 36.7464107
>      -118.7153465 36.742785
>      -118.7153296 36.7391593
>      -118.71533791 36.73753527
>      -118.7153438 36.7363838
>      2     610
>     B  13 1
>      -118.71763335 36.71507451
>      -118.71748992 36.71480774
>      -118.71754381 36.71369999
>      -118.71750723 36.7131568
>      -118.71786592 36.71228789
>      -118.71745106 36.71129755
>      -118.71716489 36.71079564
>      -118.71709787 36.71043286
>      -118.71712906 36.71006868
>      -118.71740871 36.70978478
>      -118.717644  36.709369
>      2     612
>     B  7 1
>      -118.71411256 36.77582538
>      -118.71445897 36.77550631
>      -118.71478471 36.77508229
>      -118.7149828 36.77446623
>      -118.71532537 36.77406797
>      -118.7153339 36.7717931
>      -118.71534777 36.76808916
>      2     613
>     B  3 1
>      -118.71536   36.7645405
>      2     622
>     B  4 1
>      -118.7153848 36.7572883
>      -118.7153973 36.7536622
>      2     623
>     I have been able to convert these segments into polylines, however, I am
>     not sure how one would go about computing the position along the
>     polylines.
>     Perhaps a linear referencing system?
>     Thanks!
>     Dylan
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/grass-user
> Thomas E Adams, III
> 718 McBurney Drive
> Lebanon, OH 45036
> 1 (513) 739-9512 (cell)
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150407/abcbcc1b/attachment.vcf>
