[GRASS-user] v.isochrones : error message
lcelati at cci-paris-idf.fr
Sun Apr 12 03:45:37 PDT 2015
Hello,
Thank for your replies and for your previous example.
I try to follow it. I succeed in preparing data (v.db.update, v.net, etc. ).
Moreover, i succeed in generating relevant isochrones map thanks to GUI
graphical interface. i paste below an SS :
<http://osgeo-org.1560.x6.nabble.com/file/n5200944/SS_isochrone.jpg>
But when i try to apply your v.isochrones command line :
<http://osgeo-org.1560.x6.nabble.com/file/n5200944/SS_command_line_v.jpg>
an error message appears. "method" and "cost_column" parameters do not
exist (regardless of the method used).
<http://osgeo-org.1560.x6.nabble.com/file/n5200944/SS_error_message.jpg>
I'm working with grass 7.0 and i re-downloaded the v.isochrones extension
from the repository. it seems i'm still working with the old version of the
extension because "method" and "cost_column" do not exist. I use the console
command via the GUI. i don't use the true GRASS7.0 COMMAND LINE because i
don't know where the path has to pointed to ? The "method" and
"cost_column" parameters do not exist too for the v.isochrones GUI
(graphical interface).
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-isochrones-error-message-tp5199989p5200944.html
Sent from the Grass - Users mailing list archive at Nabble.com.
