[GRASS-user] v.isochrones : error message
Markus Neteler
neteler at osgeo.org
Wed Apr 15 01:15:41 PDT 2015
Hi Martin,
On Wed, Apr 15, 2015 at 8:51 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 15/04/15 08:08, Markus Neteler wrote:
>> On Tue, Apr 14, 2015 at 10:05 AM, Moritz Lennert
>>> On 13/04/15 21:25, image93 wrote:
>>>> Is this a problem of repostory? There are several the repositories for
>>>> Grass extensions? i don't know.
>>> I found it: for grass70, the repository is
>>> http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0/ and the
>>> v.isochrones
>>> there is still the old version.
>> Seems to be solved:
>> v.isochrones.zip14-Apr-2015 04:27 133K
> This is not the correct version. I don't know where the source for this
> package is, but if you look here:
> http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/
> you'll see
> v.isochrones.zip 14-Apr-2015 04:27 214K
> Note the difference in size. And if you look inside, then you can see that
> the v.isochrones.py in the grass70 version is not the same as in the grass71
> version. The latter is the one which is currently in svn.
... could you please check if the 7.0.0 addon script is operating
properly on your server?
thanks
Markus
