[GRASS-user] Large vector file processing
Margherita Di Leo
diregola at gmail.com
Sat Apr 25 09:41:41 PDT 2015
Hi again,
On Fri, Apr 24, 2015 at 11:03 AM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Moritz,
> On Fri, Apr 24, 2015 at 10:09 AM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> On 24/04/15 09:54, Margherita Di Leo wrote:
>>> :~ > r.to.vect input=raster_tty output=vector_tty type=area
>>> Extracting areas...
>>> 100%
>>> Writing areas...
>>> 100%
>>> Building topology for vector map <vector_tty at assessment>...
>>> Registering primitives...
>>> Killed0000
>>> what does this mean?
>>> :~ > v.build vector_tty
>>> WARNING: Coor file of vector map <vector_tty at assessment> is larger than
>>> it
>>> should be (2403996039 bytes excess)
>>> Killed0000
>>> Question about "larger that it should be": What is this limitation? I
>>> guess is related to the specs of my laptop?
>> This just means that topology has not been built correctly, which is
>> probably due to some memory issues.
>> See also https://trac.osgeo.org/grass/ticket/2045.
>> One option mentioned in this report is to set GRASS_VECTOR_LOWMEM before
>> running r.to.vect in order to limit memory usage.
> Thank you for the suggestion, digging deeper I've found also
> http://lists.osgeo.org/pipermail/grass-user/2011-January/059175.html
> Now trying this option.
Unfortunately, this did not work! It took longer, but eventually the
r.to.vect yielded again the Killed0000 signal in the "building topology"
phase..
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150425/e30ccff4/attachment.html>
