[GRASS-user] r.bioclim error
Paulo van Breugel p.vanbreugel at gmail.com
Wed Aug 5 04:07:35 PDT 2015
First thing to notice is that I think variables (e.g., list with tmin
variables) should be separated by comma only, not by comma + space.
Paulo
On Wed, Aug 5, 2015 at 12:53 PM, Albert Saribekyan <
albertsaribekyan at rambler.ru> wrote:
>  I dont understand the sintax of r.bioclim
> r.bioclim tmin=tmin1_17 at PERMANENT, tmin2_17 at PERMANENT, tmin3_17 at PERMANENT,
> tmin4_17 at PERMANENT, tmin5_17 at PERMANENT, tmin6_17 at PERMANENT,
> tmin7_17 at PERMANENT, tmin8_17 at PERMANENT, tmin9_17 at PERMANENT,
> tmin10_17 at PERMANENT, tmin11_17 at PERMANENT, tmin12_17 at PERMANENT
> tmax=tmax1_17 at PERMANENT, tmax2_17 at PERMANENT , tmax3_17 at PERMANENT ,
> tmax4_17 at PERMANENT , tmax5_17 at PERMANENT , tmax6_17 at PERMANENT ,
> tmax7_17 at PERMANENT , tmax8_17 at PERMANENT , tmax9_17 at PERMANENT ,
> tmax10_17 at PERMANENT , tmax11_17 at PERMANENT , tmax12_17 at PERMANENT
> output=result
> error!!
> Unable to parse command 'r.bioclim tmin=tmin1_17 at PERMANENT,
> tmin2_17 at PERMANENT, tmin3_17 at PERMANENT, tmin4_17 at PERMANENT,
> tmin5_17 at PERMANENT, tmin6_17 at PERMANENT, tmin7_17 at PERMANENT,
> tmin8_17 at PERMANENT, tmin9_17 at PERMANENT, tmin10_17 at PERMANENT,
> tmin11_17 at PERMANENT, tmin12_17 at PERMANENT tmax=tmax1_17 at PERMANENT,
> tmax2_17 at PERMANENT , tmax3_17 at PERMANENT , tmax4_17 at PERMANENT ,
> tmax5_17 at PERMANENT , tmax6_17 at PERMANENT , tmax7_17 at PERMANENT ,
> tmax8_17 at PERMANENT , tmax9_17 at PERMANENT , tmax10_17 at PERMANENT ,
> tmax11_17 at PERMANENT , tmax12_17 at PERMANENT output=result'
> ask me how to run the module
> regards Albert Saribekyan.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150805/3bec4004/attachment.html>
