[GRASS-user] Grass 7.0 Gui interface, in Ubuntu. Problems with creation of custom colortables for raster
Kozlova Maria kclo at yandex.ru
Wed Aug 5 05:40:27 PDT 2015
Thank you!
I'll try it!
Best regards,
Maria V. Kozlova
  Information System Lab. (ISysLab)
  State Oceanographic Institute,
  Kropotkinsky per., 6,
  MOSCOW, 119034,
  RUSSIA
  tel.    +7 499 246 6448
  fax.    +7 499 246 7288
  mailto:  kclo at yandex.ru
05.08.2015, 15:35, "Veronica Andreo" <veroandreo at gmail.com>:
> Hi
>> Thanks, Vero
>> unfortunately I don't know how to create colormap rules file without GUI which is not working...
> Do you know the range of values your map takes, right?? So, let's say it goes from 0 to 100, just split values as you wish and assign colors, it will consider those intervals. Example:
> 0 black
> 20 yellow
> 40 orange
> 60 red
> 80 green
> 100 blue
> There are a lot of examples here: http://grass.osgeo.org/grass71/manuals/r.colors.html
>> And by the way, I need to change break values rather than apply certain colors to make maps visually comparble. Maybe there is a way to do it with command line?
> you set the color table for one map (map1), and then, to make them visually comparable, you set the other maps color table to the first map, like this:
> r.colors map=map2,map3,map4 raster=map1
> so, all maps will take the color table of map1.
> Cheers,
> Vero
