[GRASS-user] Problems in opening GCP Manager in 7.0.1RC1
Anna Petrášová kratochanna at gmail.com
Wed Aug 5 09:51:26 PDT 2015
On Sat, Aug 1, 2015 at 12:40 PM, Aldo Clerici <aldo.clerici at unipr.it> wrote:
> I’m having some problem in using the GCP Manager in 7.0 for Windows. In
> the panel for the selection of the raster target to display, the source
> Location and Mapset are listed and there is no way to select a map from the
> target Location and Mapset.
I fixed one problem just now in r65839, so you can try it out with a new
winGRASS build [1] when ready. But I am not sure if that fixes the problem
you have - did you get any error message in the GUI command console? The
problem is in the wizard or after the GCP application opens?
Anna
[1] http://wingrass.fsv.cvut.cz/grass71/
No problems in 6.4.4.
> Is this a bug?
> Thanks in advance
> A. Clerici
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150805/ca931378/attachment-0001.html>
