[GRASS-user] Problems in opening GCP Manager in 7.0.1RC1
    Anna Petrášová
    kratochanna at gmail.com
    Fri Aug  7 07:29:00 PDT 2015
On Thu, Aug 6, 2015 at 11:02 AM, Aldo Clerici <aldo.clerici at unipr.it> wrote:
> Hi Anna and All,
> I downloaded grass71 r65836 and repeated the rectify procedure, as follows:
> 1)      I imported the map to rectify in an xy Location (anzola_xy) in a
> Mapset named tiff.
> 2)      I imported the target map in a UTM Location (anzola), Mapset
> topografia.
> 3)      In the anzola Location (target Location) I clicked the Rectify
> button.
> 4)      In the Setup for georectification panel I selected the source
> Location and Mapset (See panel1)
> 5)      In the next panel (see panel2) I clicked on Create/edit group
> 6)      In the next panel (see panel3) I clicked  Select all and OK.
> 7)      In the panel I clicked Next (Successivo) (see panel 4).
> 8)      In the next panel (see panel 5) I clicked ‘Select target raster
> map to display’.
> 9)      In the correctly displayed map list I choosed the topo15030u4
> map  as target map (see panel 6).
> 10)   The map name was inserted in the panel (see panel 7) but when I
> clicked Fine (The Finish button) the ‘Manage Ground Control Points’ window
> was not displayed and the module seemed to be closed.
> Wath is curious is that sometime, when I click ‘Select target raster map
> to display’ the maps of the source Location (not the target) are displayed
> (see panel8) and the selection of one of the maps allows the opening of the
> ‘Manage Ground Control Points’ window (but with the wrong map in the target
> window, of course) (see panel9)
> The same procedure works well with winGRASS6.4.4 and with GRASS7.0.1RC1 on
> ubuntu.
I can see the problem from the screenshots, but I can't replicate it. You
are saying the main GCP window was not displayed - was there any kind of
error in terminal or gui command console? And when you say it happens
sometimes, does it mean it behaves randomly? (it shouldn't behave randomly)
> Thanks for your interest
> Aldo
> *Da:* Anna Petrášová [mailto:kratochanna at gmail.com]
> *Inviato:* mercoledì 5 agosto 2015 18:51
> *A:* Aldo Clerici
> *Cc:* GRASS user list
> *Oggetto:* Re: [GRASS-user] Problems in opening GCP Manager in 7.0.1RC1
> On Sat, Aug 1, 2015 at 12:40 PM, Aldo Clerici <aldo.clerici at unipr.it>
> wrote:
> I’m having some problem in using the GCP Manager in 7.0 for Windows. In
> the panel for the selection of the raster target to display, the source
> Location and Mapset are listed and there is no way to select a map from the
> target Location and Mapset.
> Hi,
> I fixed one problem just now in r65839, so you can try it out with a new
> winGRASS build [1] when ready. But I am not sure if that fixes the problem
> you have - did you get any error message in the GUI command console? The
> problem is in the wizard or after the GCP application opens?
> Anna
> [1] http://wingrass.fsv.cvut.cz/grass71/
> No problems in 6.4.4.
> Is this a bug?
> Thanks in advance
> A. Clerici
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150807/be568aec/attachment-0001.html>
