[GRASS-user] Label vector map
    henk witte
    henk.witte at groenholland.nl
    Fri Aug 21 02:24:05 PDT 2015
Dear grass-users,
I am trying to put labels in a polygon layer, but the rendering fails. The details are:
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             d.vect.EXE
  Application Version:                           7.0.0.0
  Application Timestamp:                     55ae1991
  Fault Module Name:                          libgrass_driver.7.0.1svn.dll
  Fault Module Version:                        0.0.0.0
  Fault Module Timestamp:                  55ae17e1
  Exception Code:                                  c0000005
  Exception Offset:                                00002aa5
  OS Version:                                          6.1.7601.2.1.0.256.48
  Locale ID:                                             2057
  Additional Information 1:                  0a9e
  Additional Information 2:                  0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:                  0a9e
  Additional Information 4:  0a9e372d3b4ad19135b953a78882e789
The command I use (through the GUI) is:
d.vect --quiet map=AlleKavels at GoesShape attribute_column=Kavel_nr width=1 font=romans label_color=black
Any suggestions?
Henk Witte
Groenholland Geo-energysystems
Valschermkade 26
1059CD Amsterdam
T: +31 (0)20 6159050
M: +31 (0)628176535
E: henk.witte at groenholland.nl
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150821/545fb5b7/attachment.html>
