[GRASS-user] Label vector map
Anna Petrášová kratochanna at gmail.com
Wed Aug 26 06:10:50 PDT 2015
On Wed, Aug 26, 2015 at 8:35 AM, Micha Silver <micha at arava.co.il> wrote:
> Done
> http://trac.osgeo.org/grass/ticket/2726#ticket
Sorry, I forgot to tell you, I fixed it yesterday. Testing welcome.
> On 26/08/2015 15:17, Moritz Lennert wrote:
> On 26/08/15 13:25, henk witte wrote:
> Well, this is embarrassing – I cannot open my own pack!
> I created a new workspace with a default Cartesian projection but if I
> try to unpack I get
> IOError: [Errno 2] No such file or directory: 'C:\\Users\\he
> nkwitte.GROENHOLLAND\\Documents\\grassdata/test/henkwitte/.t
> mp/unknown/8544.0\\PROJ_INFO'
> I have tries also with using the current-location-projection option, but
> same error.
> v.unpack uses a simple check to verify that the data you want to import is
> in the same projection system as the location. It does so by checking the
> PROJ_INFO file that sits in the PERMANENT mapset. But cartesian (i.e. un
> projected) locations do not have such a file, thus the error.
> This means that in its current state v.unpack cannot import data into a
> xy-location which I would consider a bug that should be reported in the bug
> tracker.
> Moritz
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150826/d976cf1f/attachment.html>
