[GRASS-user] Run grass console from a cronjob
Andrea Peri aperi2007 at gmail.com
Wed Aug 26 13:09:57 PDT 2015
<sorry the emaiil start before end the message>
I would thx for your help you and the other grass guys.
A.
2015-08-26 18:03 GMT+02:00 Nick Jachowski <njachowski at gmail.com>:
> I've had this problem from cron before and a solution I've found is to print
> all the environment variables using the linux command "printenv".
> Run printenv from your console and from the cron then compare the output and
> see what's different.
> Then when you find the critical differences set those variables from the
> head of your bash script you use on the cron.
> sample output from printenv:
> vm=ubuntu.local
> AUTOJUMP_HOME=/Users/nick
> PYTHONPATH=/Users/nick/anaconda/lib/python2.7/site-packages/:/usr/local/lib/python2.7/site-packages/:
> LOGNAME=nick
> GEM_PATH=/Users/nick/.rvm/gems/ruby-2.1.1:/Users/nick/.rvm/gems/ruby-2.1.1 at global
> LC_CTYPE=UTF-8
> GOPATH=/Users/nick/Copy/libs/gocode
> ARCHFLAGS=-arch x86_64
> On Wed, Aug 26, 2015 at 10:27 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> I'm try to run a grass session from a cronjob
>> The cron execut a bash script where I try to execute
>> grass70 -text -c /path-to-geotiff/file.tif -e /grassdata/mapset_location
>> If I try the bash script from a console it run good and without any
>> problem.
>> Bu if I try to execute the script from a crontab.
>> It stop to execute when try to do:
>> Is the grass suitable for a cronjob ?
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Andrea Peri
qwerty àèìòù
