[GRASS-user] t.rast.mapcalc question
Leonardo Hardtke
leohardtke at gmail.com
Thu Aug 27 06:22:31 PDT 2015
Oh! Thanks!
I was using GRASS 7.0.1, which has no t.rast.algebra module.
I didn't noticed there where a t.rast.mapcalc and a t.rast.algebra in newer
versions...
I installed grass71 and as you said,
t.rast.algebra expression="ndvi_diff = ndvi[0] - ndvi[1]" basename=ndvi_diff
worked perfect! Much easy than the old mapcalc and for loop version!
I'm really enjoying the grass 7 temporal framework!
Thanks for the fast (and accurate) answer!
2015-08-27 10:04 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
> Hola Leo!
> You should use t.rast.algebra (
> https://grass.osgeo.org/grass71/manuals/t.rast.algebra.html) from GRASS
> GIS 7.1 for that kind of temporal algebra operation. The command should be
> like:
> t.rast.algebra expression="ndvi_a = ndvi[1] - ndvi[0]" basename=ndvi_a
> For more examples on temporal modules, you can see:
> https://grasswiki.osgeo.org/wiki/Temporal_data_processing
> HTH,
> Vero
> 2015-08-27 9:52 GMT-03:00 Leonardo Hardtke <leohardtke at gmail.com>:
>> Dear GRASS users:
>> I'm experienced grass user... I use GRASS since I started my PhD
>> research in landscape ecology back in 2009...
>> I'm trying to calculate the difference of NDVI between consecutive dates.
>> I used to do it like:
>> i=0
>> for map in $(g.list rast pattern=MOD13Q1*_01_*); do
>> NDVI[i]=$map
>> echo "Adding: " $map
>> let i=i+1
>> done
>> for id in $(seq 0 $(echo ${#NDVI[@]})); do
>> echo $id
>> r.mapcalc "ndvi_dif2_$id = ${NDVI[$id+1]} - ${NDVI[id]}"
>> done
>> But i thing there must be an easier way using the grass 7 temporal
>> framework. So i registred my dataset and tried the following....
>> t.rast.list input=ndvi at ts
>> MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|ts|2009-01-01
>> 00:00:00|2009-01-17 00:00:00
>> MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|ts|2009-01-17
>> 00:00:00|2009-02-02 00:00:00
>> MOD13Q1.A2010337.h12v12.005.2010355100650_01_4326|ts|2010-12-03
>> 00:00:00|2010-12-19 00:00:00
>> MOD13Q1.A2010353.h12v12.005.2011005202724_01_4326|ts|2010-12-19
>> 00:00:00|2011-01-04 00:00:00
>> t.rast.mapcalc input=ndvi expression="ndvi[1] - ndvi[0]" output=ndvi_a
>> basename=ndvi_a
>> But the output is not good (see attached file: left is OK, rigth is wrong)
>> Am I doing something wrong?
>> Thanks!
>> Dr. Leonardo A. Hardtke
>> Laboratorio de Teledetección y S.I.G.
>> Centro Nacional Patagónico (CONICET)
>> Bvd. Brown 2825, 9120
>> Puerto Madryn, Chubut, Argentina
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150827/dfb7fcfd/attachment.html>
