[GRASS-user] GRASS 7 shell environment variables and prompt settings
Markus Neteler neteler at osgeo.org
Wed Dec 9 13:11:54 PST 2015
On Fri, Nov 27, 2015 at 5:18 PM, César Augusto Ramírez Franco
<caesarivs at gmail.com> wrote:
> Hello Martin
> 2015-11-26 18:08 GMT-05:00 Martin Landa <landa.martin at gmail.com>:
>> > export GRASS_PAGER=more
>> try to put this line to
>> .grass7/bashrc
> This worked for the shell environmental variables, thanks a lot
> However, as stated in my first mail, I'd like to customize my Grass prompt
> to add colors and a newline before the '>', how can this be achieved? I
> tried adding a PS1 definition inside the bashrc file but it didn't work
It needs to be added
$HOME/.grass7/bashrc
see
https://grass.osgeo.org/grass70/manuals/variables.html#setting-shell-environment-variables
but indeed, also for me it fails.
I see that
userhome, ".grass.bashrc"
is still in place:
[neteler at oboe init]$ grep bashrc *
grass.py:        grass_env_file = os.path.join(grass_config_dir, 'bashrc')
grass.py:    # instead of changing $HOME, start bash with: --rcfile
"$LOCATION/.bashrc" ?
grass.py:    #   if so, must care be taken to explicity call
.grass.bashrc et al for
grass.py:    home = location                   # save .bashrc in $LOCATION
grass.py:    bashrc = os.path.join(home, ".bashrc")
grass.py:    try_remove(bashrc)
grass.py:    f = open(bashrc, 'w')
grass.py:    for env_file in [os.path.join(userhome, ".grass.bashrc"),
.... a leftover?
Markus
