[GRASS-user] 3d model with boreholes
Alec Ventura
alecventura at hotmail.com
Thu Dec 10 14:54:21 PST 2015
I had triyed to run the extrude command over all my boreholes(with buffer), just to do a simple test:v.extrude input=PocosGrassBuffer at Map2 output=areaTest height=50 type=area
and when i turn on 3d, it gives the error:No features from vector map <areaTest at Map2> fall within current region
The EPSG code im using is 4674 - SIRGAS2000, on Qgis it looks ok, but on grass i notice that the scale is quite odd, i don't know if this can cause any bug.
To: martin.laloux at gmail.com; grass-user at lists.osgeo.org
Date: Thu, 10 Dec 2015 20:19:29 -0200
Subject: Re: [GRASS-user] 3d model with boreholes
Tanks very much for your answer Gene, im trying to follow your steps, but im having some issues:I was abble to generate the boreholes, but when i add some vectors (boreholes) and turn on 3d, nothing appears.
I had attached my algorithm and my 'pocos' shape file with my attribute table, if some kind soul could take a look and point me some directions, i will appreciate
Tanks very much,Alec.
> Date: Mon, 12 Oct 2015 22:11:24 -0700
> From: martin.laloux at gmail.com
> To: grass-user at lists.osgeo.org
> Hello, look at automate v.extrude from a table ?
> <http://osgeo-org.1560.x6.nabble.com/automate-v-extrude-from-a-table-td4978722.html#a4978730>
> , Automatic 3D geological boreholes representation (automate v.extrude
> from a table ?): my solution in Python
> <http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html>
> , and some results in 3D geological volume modeling (raster 3D): is it
> really possible ?
> <http://osgeo-org.1560.x6.nabble.com/3D-geological-volume-modeling-raster-3D-is-it-really-possible-td4980148.html>
> and GitHub: GRASS-GIS-3D-geology
> <https://github.com/mlaloux/GRASS-GIS-3D-geology>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/3d-model-with-boreholes-tp5229576p5229591.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151210/48be5a43/attachment.html>
