[GRASS-user] Map scale wrong
Alec Ventura
alecventura at hotmail.com
Sun Dec 13 12:09:38 PST 2015
So... i have converted my shape file to this projection: http://spatialreference.org/ref/epsg/4618/ on Qgis, and have created a new projection and mapset with this same epsg on Grass...But when i import the shape on grass the map scale is still crazy, it says 1:6, but my area is huge and i can see all my points. On Qgis my same file has a 1:1.183.641 scaleAnd this is a problem because when i try to make the buffers over my points i have to use a very small distance:g.run_command('v.buffer', input='PocosSad at Map3', output='boreholesGrassBuffer', type='point', distance='0.01')else my buffer covers the hole area.Anyone knows how i can fix this map scale? or why is this strange?my shape file is in attach,Very tnks
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0006.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0007.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0008.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0009.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0010.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151213/8ce82dac/attachment-0011.obj>
